Autor Tema: Problema con eje z: Return to zero  (Leído 4394 veces)
lucianoc
« en: 23 Septiembre 2020, 10:21 »
Hola, como están todos?
Bueno les comento mi problema. No importa donde le indique el ZERO del eje Z, siempre que haga clic en el botón Return to home el eje Z se va a arriba del todo llegando a su limite físico/mecanico y no deja de funcionar hasta 3 segundos después de estar golpeando el limite como si buscara un switch final de carrera a pesar de $21 = 0.
Software:
Universal Gcode Plataform (Version 2.0 [nightly])
Configuración gcode:
Código: [Seleccionar]
**** Connected to COM8 @ 115200 baud ****
Grbl 1.1h ['$' for help]
$0 = 10    (Step pulse time, microseconds)
$1 = 25    (Step idle delay, milliseconds)
$2 = 0    (Step pulse invert, mask)
$3 = 5    (Step direction invert, mask)
$4 = 0    (Invert step enable pin, boolean)
$5 = 0    (Invert limit pins, boolean)
$6 = 0    (Invert probe pin, boolean)
$10 = 1    (Status report options, mask)
$11 = 0.010    (Junction deviation, millimeters)
$12 = 0.002    (Arc tolerance, millimeters)
$13 = 1    (Report in inches, boolean)
$20 = 0    (Soft limits enable, boolean)
$21 = 0    (Hard limits enable, boolean)
$22 = 0    (Homing cycle enable, boolean)
$23 = 0    (Homing direction invert, mask)
$24 = 400.000    (Homing locate feed rate, mm/min)
$25 = 600.000    (Homing search seek rate, mm/min)
$26 = 250    (Homing switch debounce delay, milliseconds)
$27 = 0.000    (Homing switch pull-off distance, millimeters)
$30 = 1000    (Maximum spindle speed, RPM)
$31 = 0    (Minimum spindle speed, RPM)
$32 = 0    (Laser-mode enable, boolean)
$100 = 250.000    (X-axis travel resolution, step/mm)
$101 = 250.000    (Y-axis travel resolution, step/mm)
$102 = 250.000    (Z-axis travel resolution, step/mm)
$110 = 200.000    (X-axis maximum rate, mm/min)
$111 = 200.000    (Y-axis maximum rate, mm/min)
$112 = 200.000    (Z-axis maximum rate, mm/min)
$120 = 10.000    (X-axis acceleration, mm/sec^2)
$121 = 10.000    (Y-axis acceleration, mm/sec^2)
$122 = 10.000    (Z-axis acceleration, mm/sec^2)
$130 = 200.000    (X-axis maximum travel, millimeters)
$131 = 100.000    (Y-axis maximum travel, millimeters)
$132 = 200.000    (Z-axis maximum travel, millimeters)
Lo mas extraño es que con la version de Universal Gcode Sender v2.0 [nightly] funciona perfecto en todos los ejes el botón Return to home!
Los ejes X e Y funcionan perfecto en ambos softwares.
Que será?
Tendrá algo que ver la opción G54?
Citar
$# - View gcode parameters
G-code parameters store the coordinate offset values for G54-G59 work coordinates, G28/G30 pre-defined positions, G92 coordinate offset, tool length offsets, and probing (not officially, but we added here anyway). Most of these parameters are directly written to EEPROM anytime they are changed and are persistent. Meaning that they will remain the same, regardless of power-down, until they are explicitly changed. The non-persistent parameters, which will are not retained when reset or power-cycled, are G92, G43.1 tool length offsets, and the G38.2 probing data.
G54-G59 work coordinates can be changed via the G10 L2 Px or G10 L20 Px command defined by the NIST gcode standard and the EMC2 (linuxcnc.org) standard. G28/G30 pre-defined positions can be changed via the G28.1 and the G30.1 commands, respectively.
When $# is called, Grbl will respond with the stored offsets from machine coordinates for each system as follows. TLO denotes tool length offset (for the default z-axis), and PRB denotes the coordinates of the last probing cycle, where the suffix :1 denotes if the last probe was successful and :0 as not successful.
[G54:4.000,0.000,0.000]
[G55:4.000,6.000,7.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:1.000,2.000,0.000]
[G30:4.000,6.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
« última modificación: 23 Septiembre 2020, 10:36 por lucianoc »
