General => Discusión General => Mensaje iniciado por: forane en 09 Abril 2011, 14:54
Título: "Una mina de conocimientos"
Publicado por: forane en 09 Abril 2011, 14:54
Bueno ,en realidad no es una mina, pero una "vetilla" de mineral importante sí lo es:
http://mcduffee-associates.us/machining/craftmachine.htm (http://mcduffee-associates.us/machining/craftmachine.htm)
Aquí un resumen de lo que encontraréis (lamento no poder traducirlo porque no encuentro mi diccionario ;D):
Click on links below to view some of our individual student and class projects (some projects/pages are still "in-process")
    Our Emco compact 10 lathes, one with the optional factory milling attachment
    Student machined quick change tool holders
    Student designed and machined traveling steady [rest]
    Student designed and manufactured (rifle) barrel vise
    Rear mounted parting or cut-off tool holder
    Fabricating a faceplate from a donated blind pipe flange for an Emco lathe
    Fabricating a faceplate for a Craftsman lathe
    A positive thread stop for external and internal threading
    A spindle crank from salvaged and donated materials
    Adaptation of a surplus Clausing compound [top] slide as a vertical milling machine slide
    to allow milling in the lathe
    Setting gage to set lathe tool grinder table to known and repeatable angles
    Tool holder and fence to accurately sharpen lathe tool bits to known geometries
    Large parallel jaw machinists' clamps fabricated as individual projects
    A 45 tooth change gear made from 6061 T6 aluminum
    Machining a bushing from HDPE [high density polyethylene]
    5/8 X 8 ACME external thread machined by a beginning student using a tool they ground
    Laying out a t-nut during the rebuild of an Atlas lathe by a first course student as part of his project to rebuild a Craftsman/Atlas lathe.
    How a student turned a cheap lathe boring bar into a high precision boring head for a drill press or milling machine, while still being able to use it as a lathe boring bar.
Saludos. Pepe.
Título: Re:"Una mina de conocimientos"
Publicado por: okabum en 10 Abril 2011, 14:19
me gusta, algunos proyectos son muy sencillos pero que solucionan un monton de problemas.  .bien
Publicado por: jstony2000 en 10 Abril 2011, 17:57
me gusta sobre tpdo por que utiliza un combo, torno/fresa como yo :D
Publicado por: Magirus en 21 Abril 2011, 14:49
Está muy bien la página. Tiene buenas ideas y parecen bien explicadas, sobre todo para alguien que no sabe inglés, como servidor  :o
Parece de algún centro de enseñanza ¿no?
Publicado por: Santiago en 21 Abril 2011, 23:54
Gracias por el link .bien
Publicado por: forane en 16 Agosto 2011, 10:07
Pues esta página es otra mina de conocimientos:
http://rick.sparber.org/mw.htm (http://rick.sparber.org/mw.htm)
Pepe.
Publicado por: Nitinol en 16 Agosto 2011, 10:40
Muy interesante Pepe,
Publicado por: Santiago en 16 Agosto 2011, 17:44
lo mismo digo .bien
Publicado por: forane en 22 Agosto 2011, 14:45
Otra mina de conocimientos:
http://www.cabbagepatchrailway.co.uk/default.html (http://www.cabbagepatchrailway.co.uk/default.html)
Pero en estos archivos pertenecientes a la misma página, hay de todo un poco: desde test para calderas de vapor, velocidades de corte en torno y fresadora, torno Sieg, etc:
http://www.cabbagepatchrailway.co.uk/mls/g3/ (http://www.cabbagepatchrailway.co.uk/mls/g3/)
¡Que lo disfrutéis!
Pepe.
Publicado por: forane en 07 Junio 2013, 19:32
Otra que he encontrado. Algo antiguos los temas, pero válidos:
http://www.evenfallstudios.com/woodworks_library/ (http://www.evenfallstudios.com/woodworks_library/)
Publicado por: dansanc en 07 Junio 2013, 20:50
Muchas gracias Pepe,
en esos lugares puedo aprender mucho.....
Publicado por: Glezex en 07 Junio 2013, 21:08
Hola,
 Muy buenos enlaces .palmas .palmas
Digo yo...¿no sería interesante,ponerlos todos en algún sitio? (no sé en cual)
Algo así como la sección existente de blibliografía.
Publicado por: Duallight en 08 Junio 2013, 00:34
Muy buenos aportes!!! Merece una chincheta, de las gordas. .palmas .palmas .brinda
Publicado por: zapator en 09 Junio 2013, 21:51
Un gran trabajo de búsqueda el que has hecho y sobre todo muchas gracias por compartirlo con nosotros compañero, hay cositas muy interesantes en algunas  .idea
Publicado por: forane en 19 Junio 2013, 23:19
Gran cantidad de manuales para escudriñar:
https://www.google.es/#sclient=psy-ab&q=site:fioramachinery.com.au%2Fimported_pdf%2F&oq=site:fioramachinery.com.au%2Fimported_pdf%2F&gs_l=hp.3...5678.5678.1.5941.1.1.0.0.0.0.166.166.0j1.1.0...0.0...1c.1.17.psy-ab.wgzw7Z8V_fI&pbx=1&bav=on.2,or.r_qf.&bvm=bv.48175248,d.Yms&fp=b132371996933eaa&biw=1024&bih=602 (https://www.google.es/#sclient=psy-ab&q=site:fioramachinery.com.au%2Fimported_pdf%2F&oq=site:fioramachinery.com.au%2Fimported_pdf%2F&gs_l=hp.3...5678.5678.1.5941.1.1.0.0.0.0.166.166.0j1.1.0...0.0...1c.1.17.psy-ab.wgzw7Z8V_fI&pbx=1&bav=on.2,or.r_qf.&bvm=bv.48175248,d.Yms&fp=b132371996933eaa&biw=1024&bih=602)
Publicado por: forane en 22 Junio 2013, 14:51
Otra de procedencia India (Univ. de Calcuta):
(http://www.nitc.ac.in/dept/me/amc/index_files/image347.gif)
https://www.google.es/#q=site:www.nitc.ac.in/dept/me/&psj=1&ei=QpzFUfK5CciR7AbXuoHIAg&start=20&sa=N&bav=on.2,or.r_qf.&bvm=bv.48293060,d.ZWU&fp=e5e52bef33f08025&biw=1024&bih=602 (https://www.google.es/#q=site:www.nitc.ac.in/dept/me/&psj=1&ei=QpzFUfK5CciR7AbXuoHIAg&start=20&sa=N&bav=on.2,or.r_qf.&bvm=bv.48293060,d.ZWU&fp=e5e52bef33f08025&biw=1024&bih=602)
Publicado por: enrike en 22 Junio 2013, 17:45
 Hola Forane: He hecho unas " catas " y pinta muy bien.
  Gracias por tus exploraciones tecnológicas.
Publicado por: forane en 25 Marzo 2014, 23:03
El hilo estaba muerto desde hacía tiempo, pero no recuerdo dónde añadir páginas que son de interés. Así pues, reabro el hilo para colocar este documento sobre brocas y roscas. Si los moderadores no están de acuerdo, ruego lo coloquen donde proceda. Gracias.
http://www.guhring.com.mx/pdf/10-parte-tecnica.pdf (http://www.guhring.com.mx/pdf/10-parte-tecnica.pdf)
Publicado por: Borsalino en 26 Marzo 2014, 00:11
¡Gracias! forane
Publicado por: jalmirall en 27 Marzo 2014, 10:18
Muy bien Pepe me he echo unas copias y las he plastificado para tenerlas a mano en e taller
jalmirall .bien
Publicado por: Taladrín en 27 Marzo 2014, 11:08
Aprovechando añado algunos enlaces que podrían ser de interés
Equivalencias de normas para aceros:
http://www.metal-service.net/pdf/CARACTERISTIQUES%20ACERS.pdf
Equivalencias normas ISO - DIN
http://www.chavesbao.com/pdf/Equiv%20DIN%20ISO%20UNE.pdf
Un saludín pa tod@s (por si hay muyeres en el foro  .confuso2)
Taladrín
Publicado por: Borsalino en 27 Marzo 2014, 11:34
¡Gracias! Pá er saco.
Publicado por: Mig-29 en 27 Marzo 2014, 19:28
Buena info me la guardo .palmas .bien
Publicado por: forane en 06 Mayo 2014, 22:46
Unas notas someras sobre mecanizado y soldadura del la Fábrica Nacional de Moneda y Timbre Española:
Google---> teclear
 site:www.fnmt.es/documents/10179/131204/Documentación
Publicado por: Mig-29 en 06 Mayo 2014, 23:01
Al saco gracias Pepe, que disfrutes la feria de abril mi arma!!! ;D ;D ;D .brinda
Publicado por: forane en 01 Septiembre 2014, 22:55
http://www.ehu.es/argitalpenak/images/stories/libros_gratuitos_en_pdf/Ciencia_y_Tecnologia/TECNOLOGIA%20MECANICA.pdf (http://www.ehu.es/argitalpenak/images/stories/libros_gratuitos_en_pdf/Ciencia_y_Tecnologia/TECNOLOGIA%20MECANICA.pdf)
403 páginas gratuitas.
Publicado por: Forjador de sueños en 02 Septiembre 2014, 00:01
MUY BUENO Y MUY AGRADICIDO .bien .yupi
Publicado por: jmriquelmet en 02 Septiembre 2014, 03:55
gracias por los link son de gran ayuda  .palmas .palmas
Publicado por: forane en 02 Marzo 2015, 21:10
Controladores de motores de corriente continua tipo Curtis y otros:
http://www.fsip.biz/TroubleshootingManuals.html
Publicado por: forane en 06 Octubre 2015, 18:36
http://www.smithy.com/machining-help (http://www.smithy.com/machining-help)
Vídeos de mecanizado; CNC; avances y velocidades en tornos (HSS) y fresadoras (algunos en unidades anglosajonas) etc.
También:
http://www.smithy.com/product-support/cnc-mills-and-lathe (http://www.smithy.com/product-support/cnc-mills-and-lathe)
Perteneciente a esta página:
http://www.smithy.com/ (http://www.smithy.com/)
Publicado por: sanjuanino1 en 06 Octubre 2015, 20:59
No habia visto este hilo....pero les puedo asegurar que la mejor y mayor mina es este foro. Graciss a los administradores que lo mantienen!!!!
Publicado por: forane en 11 Abril 2016, 22:55
No tiene desperdicio. Perdón por revivir este antiguo post, pero es mejor que dejarlo desperdigado: así con  escribir "una mina de conocimientos" en el buscador, se encuentra.
https://sites.google.com/site/lagadoacademy/useful-links (https://sites.google.com/site/lagadoacademy/useful-links)
Pero hay dificultad para imprimir los temas. Sería interesante ver cómo imprimirlos correctamente en pocas hojas.
Publicado por: forane en 26 Julio 2016, 19:51
http://lamecaniquedevaloris.free.fr/MenuesRealisations/MenuesRealisation.html (http://lamecaniquedevaloris.free.fr/MenuesRealisations/MenuesRealisation.html)
Página en francés sin desperdicio
Dentro de;
http://lamecaniquedevaloris.free.fr/index.html (http://lamecaniquedevaloris.free.fr/index.html)
Publicado por: carlos2albertito en 30 Julio 2016, 04:12
Muy Buen hilo gracias por rescatarlo .palmas
Publicado por: forane en 20 Septiembre 2017, 22:47
https://www.google.es/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiLgMzHzrTWAhVJWBQKHUyhDGAQFggtMAE&url=https%3A%2F%2Fwww.wilhelmsen.com%2Fglobalassets%2Fmarine-products%2Fwelding%2Fdocuments%2Fwilhelmsen-ships-service---unitor-welding-handbook.pdf&usg=AFQjCNEReTzVIEDBaI5Auf7Ckkp62w767w (https://www.google.es/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiLgMzHzrTWAhVJWBQKHUyhDGAQFggtMAE&url=https%3A%2F%2Fwww.wilhelmsen.com%2Fglobalassets%2Fmarine-products%2Fwelding%2Fdocuments%2Fwilhelmsen-ships-service---unitor-welding-handbook.pdf&usg=AFQjCNEReTzVIEDBaI5Auf7Ckkp62w767w)
Libro soldadura
Publicado por: forane en 20 Septiembre 2017, 23:11
Otro libro sobre TIG
https://coestudentshop.engr.wisc.edu/training/docs/TIGBook.pdf (https://coestudentshop.engr.wisc.edu/training/docs/TIGBook.pdf)
Publicado por: Tecleador en 20 Septiembre 2017, 23:34
Gracias por los aportes,  .bien
Publicado por: forane en 15 Mayo 2018, 23:22
DIMENSIONAMIENTO Y CONSTRUCCIÓN DE UNA MÁQUINA
AFILADORA DE HERRAMIENTAS PARA TORNO
bibdigital.epn.edu.ec/bitstream/15000/10318/3/CD-6146.pdf (http://bibdigital.epn.edu.ec/bitstream/15000/10318/3/CD-6146.pdf)
Publicado por: Duallight en 25 Mayo 2018, 20:59
Forane: muy, muy bueno! Gracias por tu aporte... .palmas .palmas .palmas .bien .brinda
Publicado por: custom43 en 26 Mayo 2018, 19:52
Gracias por  los aportes .palmas .palmas .palmas .palmas
Publicado por: forane en 18 Julio 2018, 18:55
Automatización de una mesa de coordenadas xy para taladro fresador
https://repository.unimilitar.edu.co/bitstream/10654/12764/1/Libro.pdf (https://repository.unimilitar.edu.co/bitstream/10654/12764/1/Libro.pdf)
Publicado por: jalmirall en 19 Julio 2018, 20:40
Gracias Forane por esta informacion a cerca de mesa de coordenadas me ha parecido muy interesante y muy bien echa, la he impreso pues puedo necesitarla.
jalmirall
