Hola homer3,
Precisamente hoy en el foro de pcb-gcode hablan de ese fresadora . El forero dice que tiene un problema en el cuadro electrico pero en general habla bien . Te pongo el comentario.
http://www.ebay.co.uk/itm/200933892175?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649I bought the smaller version of this machine, the 3020, about 3 months ago. Unfortunately I had to go into hospital a couple of weeks after getting it, so I haven't got very far with making it do much, since I'm still convalescing and I'm starting Chemo this week.
I bought mine after watching a couple of youtube videos of it in operation, it seemed to be performing OK.
Overall the build quality seems good, with not a lot of backlash. The 2 problems I have had so far are that the pot (knob) which controls the spindle speed has stopped working, (the spindle runs at full speed continuously) and the emergency stop button has no effect. Due to the illness problem I didn't send the electronics box back to the vendor. I'm pretty good at electronics, so I expect to be able to fix these problems myself, but note that opening the (control) box requires lifting a label to access a screw fixing, so interfering with it voids the warranty quite obviously.
The package came with a CD with Mach3 software on it. The instructions are in the usual Chinglish, but I found my way through them without too many problems. Unfortunately Mach3 crashed every time I tried to run it, but I solved that by downloading an up-to-date copy from the net. Once this was installed I was able to get it running with the Key from the CD, this is obviously a rip-off, since you're supposed to pay the authors for a Key of your own, I leave this to your own conscience. There are freeware CNC controllers available including the highly regarded EMC2, although this requires you to run under Linux. Settings for Mach3 are provided, and work quite satisfactorily if followed to the letter. It's a bit of a complication to your workflow if you have to process files in Eagle under Windows to get g-code and then export them somewhere that the linux box can see them. This isn't a big problem for me as I have a network, multiple PCs and NAS, but
there's something to be said for being able to process all your files under a single OS, including visualize them.
I did get as far as trying to rout a board, but although it was successful to a degree, the cut was overly wide and the tool wore its end away in short order. Tools are easily obtainable though, the collet grips anything that fits in a Dremel, I think.
Like many other processes, I think the quality of the output depends on the experience of the operator, I expect to get good results from this system once I get some time in. I see there are a number of hot print heads for 3D available at reasonable prices and although the machine will only accept a 2" deep workpiece, I may try buying one to see if I can fit it instead of the spindle.
All-in-all, despite the problems with the electronics, I would have no hesitation recommending the machine to anyone with a good level of competence with electro-mechanical devices. Any machine will wear, and the operator must accept the responsibility for maintaining it.
También algún enlacen donde la mandan desde inglaterra.
http://www.ebay.co.uk/itm/200933892175?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649http://www.ebay.co.uk/itm/CNC-ROUTER-ENGRAVING-DRILLING-AND-MILLING-MACHINE-ENGRAVER-3040-BALLSCREW-a1-/190855409602?pt=LH_DefaultDomain_3&hash=item2c6fde6fc2Saludos.
