Autor Tema: Torno Smart and Braun  (Leído 2715 veces)
« en: 10 Diciembre 2013, 12:58 »
Un torno no muy habitual en nuestro pais,casi seguro en imperial pero si no esta muy picado una gran maquina.
 http://www.milanuncios.com/otros-motor/torno-metal-110cm-smmart-brown-londres-113090862.htm
Desconectado dansanc
Re:Torno Smart and Braun
« Respuesta #1 en: 10 Diciembre 2013, 13:51 »
Esa sierra escuadradora está muy linda.....
El torno es el modelo 1024, un torno de precisión.
Aquí hay una descripción donde dice que  las manivelas
tenían graduaciones métricas y en pulgadas.
Sumarizando:  UN SUPER TORNO.  Buena alternativa para
los que no quieren un torno chino.
"Manufactured from the late 1950s until the early 1990s (in variable-speed drive Mk. 2  form) the Smart & Brown 1024 5.5" x 24" toolroom lathe was, and still is, a sought-after machine. It was manufactured to a very high standard - and not down to a price (which, as a result, was considerable). On the original Mk. 1 twelve spindle speeds were available, from 30 to 2500 rpm, with the headstock pulley running in its own ball journal bearings concentric with, but independently of, the main headstock spindle. A 3-speed, 3-phase motor rated 1/1.5/2 H.P. was located in the base and drove upwards to a 2-speed gearbox that incorporated a multi-disc friction clutch to smooth out speed changes. The speed-change gearbox was operated by a lever and the settings could be altered without having to move a belt  from pulley to pulley.
With a Type D1-4" nose and running in SKF type N.N.30.K double-row cylindrical roller bearings the heat-treated spindle was bored 11/4" and accepted collets up to 1" in capacity. Filtered oil was pumped automatically to the headstock, speed-change and screwcutting gearboxes while the apron was lubricated by a small pump contained within its base that was activated by the sliding action of the carriage assembly.
Constructed from a high-grade nickel iron and flame hardened, the lathe bed was provided with what the designers considered the best combination of V and flat surfaces to locate and maintain the relative positions the headstock, carriage and tailstock over a very long service life. To help rigidity and vibration absorption the lathe was mounted on a cast-iron base of great weight.
Produced as the "1024 VSL" the Mk. 2 version, whilst having the same capacity and being mechanically almost identical to the Mk. 1 (although cosmetically altered to make it look "modern") was fitted with a very effective push-button-controlled variable-speed drive unit that gave both forward and reverse speeds from 40 to 2500 rpm from a 3-phase, 3 hp (2.25 kW) motor.
Dual metric/English micrometer dials and a coolant system were fitted as standard and the automatic lubrication of the leadscrew, saddle, apron and headstock was fitted to all years of production..""
« última modificación: 10 Diciembre 2013, 14:04 por dansanc »
Duallight
« Respuesta #2 en: 10 Diciembre 2013, 21:44 »
Hace unos meses se há vendido uno (Smart Brown 1024) que parecia em muy buenas condiciones, en Portugal, se notaba la pintura original com muy pocos aranazos, me parece há sido vendido por 1000 ó 1200 €. Hay hecho una pesquisa en Tony Lathes, UK, y efectivamente és una grand y muy buena máquina, la bancada és de ferroníquel y pesa de cojones, para su tamaño, me parece que circa de 1200 KG. .bien .brinda
delichon
« Respuesta #3 en: 10 Diciembre 2013, 23:43 »
