Autor Tema: HERRAMIENTAS DE TRONZAR  (Leído 1843 veces)
« en: 18 Junio 2017, 10:25 »
He estado mirando herramientas para tronzar y he encontrado precios interesantes, espero que a alguien le sirva de algo.
Porta lama de 32 x 3 de lama y soporte  que coge a la torreta de 32 mm :
http://www.ebay.com/itm/SMBB3232-Cut-off-the-cutter-bar-Cutting-tool-rod-SPB-cutter-32mm-holder-SPB32-/291973474169?hash=item43faf9a779:g:2lgAAOSwcUBYMrke
Porta lama de 32 x 3 y soporte que coge a la torreta  de 20 mm:
https://www.banggood.com/SMBB2032-Grooving-Cut-Off-Blade-Holder-CNC-Milling-Cutter-Holder-For-SPB32-Blade-p-1157761.html?rmmds=search
http://www.ebay.com/itm/SMBB2032-Tool-Holder-Grooving-Cut-Off-Cutter-Bar-Tool-Rod-SPB-Screw-Spanner/252860163386?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D41375%26meid%3D54ce023221554d51b1f540671c9ce32b%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D291973474169
Porta lama de 32 x 3 y soporte que coge a la torreta de 25 mm:
http://www.ebay.com/itm/SMBB2532-Cut-off-the-cutter-bar-Cutting-tool-rod-for-SPB-cutter-holder/302236620559?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D41375%26meid%3D178ea73f303d4c208d3cdd00ecf61578%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D291973474169
Porta lama de 26 x 3 soporte que coge a la torreta de 20 mm:
http://www.ebay.com/itm/SMBB2026-Cut-off-the-cutter-bar-Cutting-tool-rod-SPB-cutter-20mm-holder-SPB26-/291973472943?hash=item43faf9a2af:g:2lgAAOSwcUBYMrke
Porta lama de 26x 3 y soporte que coge a la torreta de 25 mm:
http://www.ebay.com/itm/SMBB2526-Cut-off-the-cutter-bar-Cutting-tool-rod-SPB-cutter-25mm-holder-SPB26-/302167601808?hash=item465a97b290:g:2lgAAOSwcUBYMrke
Lama de 32 x 3:
http://www.ebay.com/itm/SPB332-S-Cut-off-the-cutter-bar-Cutting-tool-rod-FOR-SP300-ZQMX3N11/302102601994?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D41375%26meid%3D178ea73f303d4c208d3cdd00ecf61578%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D291973474169
Lama de 26 x 3:
http://www.ebay.com/itm/SPB326-S-Cut-off-the-cutter-bar-Cutting-tool-rod-FOR-SP300-ZQMX3N11-SPB26-3/302102634497?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D41375%26meid%3D54ce023221554d51b1f540671c9ce32b%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D291973474169
Placas de corte de  3 mm para las lamas que he puesto:
https://www.banggood.com/10pcs-ZQMX3N11-1E-SP300-YBC251-Cut-Off-Grooving-Inserts-for-ZQ2020-3-Holder-p-1091453.html?rmmds=myorder
Es a modo de orientación siempre puedes mirar por las referencias que he puesto en otras páginas y comparar precios. Pero me parecen precios bastante razonables.No he puesto varios enlaces de Banggood porque están agotados y no sé cuando los volverán a poner pero es donde yo he comprado mientras ha habido. Por  dar más información los pongo.
Lama de 32 x 3:
https://www.banggood.com/SPB32-3-32mm-Part-Off-Blade-Grooving-Cutter-for-ZQMX3N11-1E-Insert-SMBB163220322532-Holder-p-1096831.html?rmmds=myorder
Lama de 26 x 3:
https://www.banggood.com/SPB26-3-26mm-Part-Off-Blade-Grooving-Cut-Off-Tool-for-ZQMX-3N11-1E-SP300-Insert-SMBB1626-Holder-p-1058742.html?rmmds=myorder
Porta lama de 32 x 3 y soporte que coge a la torreta 25 mm:
https://www.banggood.com/SMBB2532-Tool-Holder-With-SPB32-3mm-Blade-Grooving-Cut-Off-Cutter-For-3mm-Cut-p-1088727.html?rmmds=myorder
Esta venía con la lama incluida y fue la que en su día compré yo. Lástima que no haya ahora mismo.
Yo suelo mirar en Banggood de vez en cuando porque van poniendo y quitando cosas y a veces salen precios interesantes.
Re:HERRAMIENTAS DE TRONZAR
« Respuesta #1 en: 18 Junio 2017, 10:59 »
Acabo de ver otro que  tenía guardado pero no vi.
http://www.ebay.com/itm/1pcs-SMBB2526-1pcs-SPB26-3-10pcs-SP300-ZQMX3N-3mm-cut-knife-/302318426447?hash=item466395194f:g:2lgAAOSwcUBYMrke
Un porta de lama 26 x 3 con sopote para torreta de 25 mmm  +  lama de 26 x 3 + 10 placas de corte de 3mm
« Respuesta #2 en: 18 Junio 2017, 15:17 »
Buenos aportes..el que no tenga herramientas de tronzado a estos precios es ya por que no quiere .brinda
« Respuesta #3 en: 18 Junio 2017, 15:43 »
Se trata de ponerlo fácil.  .bien.
Y de paso quitarte algo de trabajo a ti  ;D.  .brinda  .bien
