Autor Tema: "Una mina de conocimientos"  (Leído 17935 veces)
« en: 09 Abril 2011, 14:54 »
Bueno ,en realidad no es una mina, pero una "vetilla" de mineral importante sí lo es:
http://mcduffee-associates.us/machining/craftmachine.htm
Aquí un resumen de lo que encontraréis (lamento no poder traducirlo porque no encuentro mi diccionario ;D):
Click on links below to view some of our individual student and class projects (some projects/pages are still "in-process")
    Our Emco compact 10 lathes, one with the optional factory milling attachment
    Student machined quick change tool holders
    Student designed and machined traveling steady [rest]
    Student designed and manufactured (rifle) barrel vise
    Rear mounted parting or cut-off tool holder
    Fabricating a faceplate from a donated blind pipe flange for an Emco lathe
    Fabricating a faceplate for a Craftsman lathe
    A positive thread stop for external and internal threading
    A spindle crank from salvaged and donated materials
    Adaptation of a surplus Clausing compound [top] slide as a vertical milling machine slide
    to allow milling in the lathe
    Setting gage to set lathe tool grinder table to known and repeatable angles
    Tool holder and fence to accurately sharpen lathe tool bits to known geometries
    Large parallel jaw machinists' clamps fabricated as individual projects
    A 45 tooth change gear made from 6061 T6 aluminum
    Machining a bushing from HDPE [high density polyethylene]
    5/8 X 8 ACME external thread machined by a beginning student using a tool they ground
    Laying out a t-nut during the rebuild of an Atlas lathe by a first course student as part of his project to rebuild a Craftsman/Atlas lathe.
    How a student turned a cheap lathe boring bar into a high precision boring head for a drill press or milling machine, while still being able to use it as a lathe boring bar.
Saludos. Pepe.
okabum
Re:"Una mina de conocimientos"
« Respuesta #1 en: 10 Abril 2011, 14:19 »
me gusta, algunos proyectos son muy sencillos pero que solucionan un monton de problemas.  .bien
Desconectado jstony2000
« Respuesta #2 en: 10 Abril 2011, 17:57 »
me gusta sobre tpdo por que utiliza un combo, torno/fresa como yo :D
Minicompresor Casero.
« Respuesta #3 en: 21 Abril 2011, 14:49 »
Está muy bien la página. Tiene buenas ideas y parecen bien explicadas, sobre todo para alguien que no sabe inglés, como servidor  :o
Parece de algún centro de enseñanza ¿no?
« Respuesta #4 en: 21 Abril 2011, 23:54 »
Gracias por el link .bien
« Respuesta #5 en: 16 Agosto 2011, 10:07 »
Pues esta página es otra mina de conocimientos:
http://rick.sparber.org/mw.htm
Pepe.
Desconectado Nitinol
« Respuesta #6 en: 16 Agosto 2011, 10:40 »
Muy interesante Pepe,
Gracias
Fresadora Kondia FV-1, Torno Optimum D 240 x 500, Soldador Inverter, Prensa 8T casera, Taladro columna
« Respuesta #7 en: 16 Agosto 2011, 17:44 »
lo mismo digo .bien
« Respuesta #8 en: 22 Agosto 2011, 14:45 »
Otra mina de conocimientos:
http://www.cabbagepatchrailway.co.uk/default.html
Pero en estos archivos pertenecientes a la misma página, hay de todo un poco: desde test para calderas de vapor, velocidades de corte en torno y fresadora, torno Sieg, etc:
http://www.cabbagepatchrailway.co.uk/mls/g3/
¡Que lo disfrutéis!
Pepe.
« Respuesta #9 en: 07 Junio 2013, 19:32 »
Otra que he encontrado. Algo antiguos los temas, pero válidos:
http://www.evenfallstudios.com/woodworks_library/
Desconectado dansanc
« Respuesta #10 en: 07 Junio 2013, 20:50 »
Muchas gracias Pepe,
en esos lugares puedo aprender mucho.....
Glezex
« Respuesta #11 en: 07 Junio 2013, 21:08 »
Hola,
 Muy buenos enlaces .palmas .palmas
Digo yo...¿no sería interesante,ponerlos todos en algún sitio? (no sé en cual)
Algo así como la sección existente de blibliografía.
Duallight
« Respuesta #12 en: 08 Junio 2013, 00:34 »
Muy buenos aportes!!! Merece una chincheta, de las gordas. .palmas .palmas .brinda
zapator
« Respuesta #13 en: 09 Junio 2013, 21:51 »
Un gran trabajo de búsqueda el que has hecho y sobre todo muchas gracias por compartirlo con nosotros compañero, hay cositas muy interesantes en algunas  .idea
